Disconnected double wall gas exhaust pipe
Someone working on my house pulled my double wall pipe apart that was used for the gas exhaust for my furnace. I am trying to get the bottom section back into the top but for some reason I can't get it high enough. The bottom section seems to have been pushed down through the floor and I can not get it to pull up and align. What can I do! It is getting cold.
    Jamie Hall Member Posts: 26,830
    It takes real force to damage the wall of a pipe that way… I wonder what other damage has been done, starting right at the furnace or boiler.
    I'd much rather see you replace the whole thing — furnace or boiler to termination above the roof. That damaged section must be replaced anyway.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,005
    Hi, I see that the two sections are disconnected, but touching. Once lined up, they should push together and then a little twist locks them together. A handyperson should be able to do this. Once in place, redo the steel strapping to hold it in place. By rights, whoever did this should put it right at no charge, but I'm not sure you want them back on the property 🫤
    Yours, Larry
    EdTheHeaterMan Member Posts: 11,560
    Could that have been pushed down from the roof by a worker on the roof? Then they tried to pull it back up after the damage was done???
    I agree with @Jamie Hall. that needs to be inspected from the equipment connection all the way to the roof termination. With that much force one of the adjustable elbows may also be separated. The leak may be allowing carbon monoxide into the home.
    HVACNUT Member Posts: 7,227
    I hope they let you know and you didn't find that by accident.
    As mentioned, the pipe is "twist lock" but it's the pieces going through the roof that need to do the twisting. Only the penetration piece shouldn't be able to twist at all because it should be sealed around the flashing and storm collar.
    But obviously that section of roof was replaced. And the daylight means the top piece should spin like a top.
    The weight of the flue must be supported, and not by the way shown.
    I would carefully go over ALL flue joints going all the way back to the appliance(s).
    EdTheHeaterMandelcrossvLarry Weingarten
  • Dennis
    Dennis Member Posts: 124
    I see this with roofers on a regular basis. You'll need to release the pipe from the roof flashing, it shouldn't be screwed to the storm collar or flashing but I bet it is. Support the vent lower and work the pipe back together. Follow up with a few screws into the b-vent outer jacket. Make sure the pipe is not touching any wood. If it is wrap the wood with sheet metal.
