Headache with heil furnace and an amazon smart thermostat
okay so back in may i had purchased a amazon smart tstat installing was a pain since i swear i still have 70s wires had to rig up some jumps to make the ac work because it went from a four wire no c to a setup that needed a c wire but now as we get to the colder months i have run into the issue where now it wont run the heating ac worked wonderful though. The furnace will kick on, but it blows just air. Not hot and not cold, and now the thermostat has no power i assume. My wife used the G wire as the C wire on the thermostat, and jumped the Y to the G on the furnace so the fan would still work with the heat. I have included some pictures of the thermostat wiring and the furnace wiring. Any and all help would be greatly appreciated. Thank y'all in advance.
462553358_953575180150175_4651255352575230443_n.jpg 462544649_484433524614077_5498843721873439913_n.jpg 462547722_1285914322836040_5229770350483658427_n.jpg 462548988_3877183895852771_220826023674164715_n.jpg 462555802_544748601518309_3263541805243456955_n.jpg 462557263_8718152744931786_5224172431908958835_n.jpg
    Jamie Hall Member Posts: 27,313
    First, the colour of the wires is irrelevant. Electricity is colourblind.
    Now. What I would suggest is that you go all the way back to square one. Find the wiring diagrams for your thermostat and you Heil control, and the instructions for what get connected to what. And follow them.
    Off the top of my head — I'm not familiar with either of those units — I suspect you need connections to Rh (and a jumper to Rc), W (not W2, unless this is a two stage furnace), C, G and Y on the thermostat. I can't read the labels on the control.
    If you post the wiring diagrams and instructions here, @EdTheHeaterMan is a wizard at figuring these things out and may help.
    EdTheHeaterMan Member Posts: 12,128
    Once I know the designation of all the terminals on the Heil. I can get you where you need to be.
    HVACNUT Member Posts: 7,424
    Take the White wire at the thermostat from W2 and land it on W.
    The door to the furnace must be on to power the thermostat.
    Y and G are jumped so you obviously have no "fan only" control.
    When possible, run a new 18/8 wire and connect all correctly.
