Need help with Honeywell Thermostat setup
Hi. I'm setting up a new Honeywell programmable thermostat and I am being asked to select my heating system type and equipment type. I have a Weil-McLain furnace model 1107-2. I don't know which options to pick. Any help would be appreciated. Here are my choices. Thank you
is it oil
Or gas?
hot water or steam? fin tube or convectors or standing cast iron radiators?
It is gas fired hot water. I have floor boards going around the bottom of the walls.
radiant heat
Thanks @pecmsg. I was leaning towards that one because it says boiler. But it isn't really radiant heat. So that's what's throwing me.
radiators!
#3 for system type
#9 for heating equipment type
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
