Scariest job?
Let's gather around the fire again for some more spooky job stories to kick off Halloween week. Who's got a good one?
President
HeatingHelp.com0 -
January 1979 in Elmont, Meacham Ave about a 1/2 mile south of Hempstead Turnpike, get a no heat call. Multiple police cars in front of house, cop lets me in. Dead body in hallway covered by sheet. Neighbor found the old lady dead and called cops, they can't leave body unattended until coroner arrives and it's a busy day, going to be a while. Cop goes in basement and gets phone number from sticker on boiler and calls but doesn't tell dispatcher the situation.
Had to step over her legs to get to basement door and twice more on trips to truck.
Hope you had some sort of CO detection equipment.
The first time commissioning a commercial boiler. That delayed ignition can really haunt you.
- Is the oil pressure correct?
- Is the gas pressure correct?
- Is there air in the gas pipe and that is why it is taking so long?
- Is that letting fuel into the combustion chamber all that time with no ignition?
Every large boiler I commissioned gave me the willies until it just lit off smoothly. Then I would say "As expected, Perfect"
The small residential jobs were never a problem… They would puff sometimes and that was not so scary!
I do remember a time when I was called to an apartment complex by our sales department at about 11:00 AM, to assure the apartment complex owner that we were experienced on their 8 GPH boilers in the 7 buildings on campus. (i worked for a fuel dealer at the time) The salesman was trying to close a deal to sell them oil. In the corner of my eye, I noticed a couple of guys working on one of the buildings boilers. (No big deal)
Later that evening at around 11:00 PM I got a call from the salesman. "Do you remember that apartment complex we looked at this morning?" "Yes" I answered. "Well they have a boiler that was down all day and the guys working on it just asked the super 'Do you know anybody else that knows how to work on these things?' and I thought of you"
So I drove the 50 miles from my home to the apartments and met with the super. The whole trip I was thinking those guys were there for at least 11 hours. I wonder: How many times did they hit that reset button and did not get it to ignite? I also kept a red binder that had every oil burner instruction book I ever worked on as part of my tool kit.
Sadly I did not have the book for that boiler/burner combination, but I had the next size smaller and hoped that was close enough. In those instructions there were the electrode settings for the smaller burner and the larger burner looked very much the same. I set the electrodes and tested the spark. Everything was ready for lift off. (rocket launch terms use intentionally)
I told the super that he had to get everything that was combustible away from the boiler, and for about 20 feet away from the front of the boiler. I have burned off saturations before but nothing on a boiler this big, and there was no way I was going to rip out a combustion chamber at 12:45 at night. I did tell the super that the flames from the inspection door may shoot out like a blow torch as far as 15 feet. You see, to burn off a saturation you need a good clear vent and a way for the excess oil to actually burn away. So leaving the inspection door open was part of the prep work. Another thing was to be able to keep the burner blower wheel running without adding more fuel to the flame once it ignited. So there I was with a wire cutter in hand, to shut down the solenoid valve. Finally, once you get it lit, you need to open the air gate full to get as much combustion air as possible into that oil soaked chamber.
Then I lit the burner, Flames shot out the inspection opening about 5 to 6 feet (Less than I thought) and I cut the fuel and opened the air gate. The boiler was now getting hot and the tenants were going to warm up soon. It took about 6 minutes for the flames to stop shooting out the inspection port. The saturation burned for about 45 minutes before I could see that it would need the fuel back on to continue to operate. The last thing you need to see on a saturation burn off, is that when the burner stopped, the flame goes out. That took another hour for that to happen. After spending about 3 hours total on sight, the burner was safe to operate automatically.
We got the oil account and the customer was satisfied that we knew what we were doing on oil heat service. The following day I sent one of our other technicians that were more familiar with commercial boilers to make sure it was set up properly with electrode settings and air fuel adjustments with a combustion testing kit.
That was a scary Friday night.
4 -
Hope peeps dont mind one from my telco days.
Our 2-man service truck gets called out to a rural area, most of the people around this lake have no phone service. A bad storm had passed thru the night before. Via some good test readings, we box the trouble in fairly quick to find a big pine tree down that had collected the 14.4kv primaries and our telcom cable. Wires were all on the ground. Everything was quiet, this happened many hours earlier. We discussed maybe trying to get a bit closer to see how bad the damage was, but thought it was wiser to wait until the power company showed up. We drove to the other side of the bush area to see how things looked there, for a repair plan. Thats when black smoke started billowing over top of the tree line in our original area. We rushed back to find those primaries jumping and humming , small fires starting everywhere the wires touched ground or trees.
Power company had closed a fuse to see if the line would clear itself (sometimes it's just a branch).
Moral of the story is.. even if you think a line is dead, you even know its dead, there's always the chance that someone else might turn it on. We have no "lockout" system with the power company, so thats why the standard is to not touch anything at all until power guys show up and says okay. Glad we followed our training that day.
Oh, in case you're wondering, the power fuse tripped out again, fires went out (everything was wet), power company repairs theirs, we repaired ours, everyone was happy.
Currently in building maintenance.4 -
Need a shocked response for that one.
Technically, this wasn't a job I was on, but it happened, oh, about 40 years ago when I was in L.A. attending university. Thinking about it in the years since it happened, I still get shivers, and think this might have been the stupidest moment of my life.
I was walking down the street where there were a bunch of small shops along an older commercial avenue, on the way to the mall and minding my own business when I heard sirens approaching. I didn't think much of it but then 3 (maybe 4 - I just don't remember) cop cars came screeching around the corner behind me and racing up the street.
They came to a screeching halt on the street not 20 or 30 feet in front of me. The cops jumped out of their cars with their guns drawn. It seemed like it was an army of cops but it was probably only 4 or 5. I froze and looked around thinking "Are they after me?" I heard a shot, and guy with a gun came running out of the shop right in front of me. I had no clue what to do! It was like time slowed down and it was all happening in slow motion. The robber took off running toward me, or toward my direction down the street (away from the cops). Without even thinking I tried to tackle the robber as he was running away. He tripped and I ended up just hanging onto his legs. he was kicking me and got me in the face and shoulders once or twice but I hung on to one of his legs and was pulling on his leg as hard as I could … just like I'm pulling yours right now!!! 😎
Single pipe steam
Weil-McLain EG/PEG -50
175K/145K in/out (454 sf)4 -
When I was in high school I worked for an electronics company that made alarm systems. It was in the middle of a hot humid summer in the deep south when I was installing one of the systems. After some serious contortions, I was finally wedged into the HVAC closet installing a heat sensor above the door. It was a setup where the air handler was set over a single large return air duct. The half height access door was about 3' above the floor. I was sweating profusely while wrapped around the bare copper A/C line set. I went to strip the ends of the wire and the next thing I knew, I was back out on the floor. After some investigation I found that the line set was grounded and the bell wire for the sensor was wired into the hot side of an attic light fixture. It's a lucky thing the condos had been left empty for a while and the electrician that had 'hooked me up' was long gone…
After typing up the last story another one came to mind. While in college I worked for the local two-way radio shop. I went on a service call to the police department one night. While I was working, one of the officers came in and was acting a bit odd. I had just wrapped up the repair as he came out of a closet with a shotgun. He was waving it around asking the dispatcher if they had ever figured out how to break it open and unload it. That was right as he pointed it square at me and pulled the trigger. Turns out it was a toy gun, and unloaded, but maybe he underestimated the impact... Neither the officer or I slept for a few nights. Me from the shock of it, him from wondering if he would keep his job.
2
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
