Kitec! Uhg!
Intplm.
Intplm. Member Posts: 3,005
I recently had to replace some Kitec fittings, (copper to Kitec) for a repair on a fin tube heating system.
Of course, the parts are hard to find. Has anyone used another type of fitting? Maybe a common pex-to-copper adapter?
  • Ironman
    Ironman Member Posts: 7,903
    edited October 2024
    Roth’s Pex-Al-Pex fittings and tubing will work.
    Of course, you’ll need the pressing tongs or the manual press tool.
    Teal Corp. sells the Rems tongs and they’ll work on a Milwaukee or Ridgid 18v press tool.
    Pex-Al-Pex is a different ID than regular pex, so the correct fitting must be used.
    RE Michel carries the Roth fittings.
    Bob Boan
    PC7060Intplm.
  • Intplm.
    Has anyone used Oedeker cinch pinch crimp fittings? I have some and was thinking of using them.
    They appear to be a good choice. I have used them on many types of Pex. But not on Kitec.
    hot_rod Member Posts: 27,413
    edited November 2024
    the outside diameter of the Kitec may not allow you to get a chinch ring on?
    You want a fitting with dual o rings with zPAP tube.
    Did you try Hydronic Alternatives or this company in Canada that makes Kitec replacement fittings
    https://veratek.ca
    Intplm.
