Plumber advises to keep air inlet when removing house trap
The fresh air vent on a house trap satisfies the plumbing code that every trap must have a vent. With removal of the house trap the home plumbing will be vented through the stack vent through the roof and possibly other fixture vents going thru the roof as well.
House traps are no longer required in most areas.
Robert W.
Energy Kinetics
What is wrong with extra vents? I like inverted U s to prevent stuff falling into drain line.
When it comes right down to it, if you leave the vent installed it will be an extra vent. There's no harm in leaving it there.
I’d have to disagree. You now how the entire street (and more) venting out of the side of your house. It’s no longer a fresh air INLET, it’s just allowing sewer gases to expel at an unacceptable height off the ground. With the house trap installed, the fresh air INLET is in front of the trap, not behind it.
@Danny Scully Very good point! One would think it would be against plumbing code to leave the air inlet in if there's no trap. One wonders how often plumbers find such a setup.
Good point Grasshopper, but it's no worse than a street manhole cover. I'm keep my house trap and my Fresh Air Inlet.....Mad Dog
Real stench comes when house trap leaks and there's no vent.
Nothing wrong leaving house trap.
I had a call once that a woman dropped her 3 carrot engagement ring in the water closet an accidentally flushed down the drain, told her to wait two weeks to allow the ring to eventually reach the house trap.
When I got to the job using a small soup ladle eventually got the ring out of the house trap.
what came out first was some grease then some small pocket change then the ring.
Krrp your house trap, occasional cleaning is required.
Jake
Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
- 50 Industry Classes
