Main bathroom ceiling opinions
2»
  • ChrisJ
    ChrisJ Member Posts: 17,357
  • DCContrarian
    DCContrarian Member Posts: 1,456
    If you're going to play plumber, you have to start thinking like a plumber. Practice repeating this phrase:
    "Drywall is a removable panel."
    Once you've mastered that you can move on to, "Sweep? Do I look like the maid?"
    ethicalpauldelcrossvPC7060
  • ChrisJ
    For what it's worth I like the work this guy does.
    He makes it look so easy.
    delcrossvethicalpaul
    Jamie Hall Member Posts: 27,324
    It's really a fine art — and the ones who do it — the few — do it very well indeed.
    delcrossv
    HVACNUT Member Posts: 7,425
    Other?
    Do they make a 7 day mud?
  • ChrisJ
    edited October 2024
    I hope not.
    Even I use 20 minute often.
    I currently have a bag of 90 because I'm doing multiple ceilings and wanted time to work but I probably should've went 45.
    When it's heavy 90 minute takes a good 2 hours before you can work on it again. At least that's my experience but I'm far far far from an expert. I can make things pretty but it takes me time.
    mattmia2 Member Posts: 16,687
    Drywall
    about 45 is as fast as i can clean the tools.
    the finish coat plaster they use is mostly plaster of paris and sets fast.
