necessary to neutralize condensate?
i have all PVC drain lines. will the acidic condensate damage these pipes if not neutralized ? or is that only for metal drain pipes?
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,464
    It the municipal sewer is Cast Iron, you'll need to. Mad Dog
    Jamie Hall Member Posts: 27,004
    Or an older waste water pipe system or septic system with cast iron lines…
  • camiarrobino
    camiarrobino Member Posts: 83
    i have none of these. i have pvc everywhere in my basement, and a pvc drain line in my yard going out into the street. unsure of what exactly the town has in the street
    I probably shouldn't say this — but when it gets to the street it will mix with another … um… stuff and not be a problem. Might check with whoever runs the sewer system, though. They may have a different opinion.
