Circa 1920 levered manual steam valve
wphooty67
Member Posts: 1
Hello,
I have a number of these valves on my radiators that leak. I want to know what my best option is. I can't read the manufacture seems moul.....
Qg a
If they're leaking past the stem, you can repack them.
Its MOUAT.
See:
2 pipe system? Looks like a regulating valve.
Mepco still makes those, be prepared for sticker shock.
You can't just swap them for a regular valve without additional work.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
I agree, just replacing these with standard valves will cause all kinds of trouble. Use the MEPCOs.
@gerry gill is our resident Mouat guy, hopefully he will chime in.
Consulting2 -
Mouat vapor system. They are special metering valves.
- 117 Geothermal
