VXT-24 Water Heater
Hello
I recently purchased the VXT-24 automatic water feeder. I am about to install it and notice an unusual orientation of the valve that came floating inside the enclosure. In the pictures that I’ve seen it shows the two electrical terminals jetting out to the left if you’re looking straight at it. If I were to install it where the stud of the screw the valve, it shows it covering the LED display. (Picture enclose)
did this feeder come to me broken or wrong? Any input is appreciated
Paul
    Jamie Hall Member Posts: 27,185
    Can you rotate that green plastic piece with the wiring terminals in the metal bracket? Should be possible — considering that I see 7 possible slots for the index on the plastic piece.
  • PaulLandon23
    PaulLandon23 Member Posts: 2
    i suppose I could but I’m not sure how to. It seems molded
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,062
    Hi, I see what looks like the end of a bolt in the center of the plated metal piece. Can you get to the back side of it to see if you have a bolt head there?
    Yours, Larry
    Steamhead Member Posts: 18,381
    Consulting
