Workmanship
Alan (California Radiant) Forbes Member Posts: 4,708
edited October 2024 in THE MAIN WALL
There are often existing boiler installs where I know exactly who did the work by their piping workmanship.
This guy was a perfectionist and it stands head and shoulders above anyone else’s. From him, I learned to install copper x male unions on relief valves and female unions on x-tanks. It makes the next guy’s job so much easier.
But I still can’t cut insulation like he does.
delcrossvCLambHeatingHelp.comMad Dog_2ChrisJTeemokSuperTechMikeAmannEdTheHeaterManIntplm.WaherHVACNUT
  • SlamDunk
    SlamDunk Member Posts: 1,803
    yeah, that is very nice work. Making it easier for the next guy is the finest way to show your craftsmanship.
    Alan (California Radiant) ForbesdelcrossvMikeAmannEdTheHeaterMan
  • delcrossv
    delcrossv Member Posts: 2,203
    Very nicely done!
    What's with the ground wire on the tank?
    EBEBRATT-Ed Member Posts: 20,145
    @delcrossv
    Some locations want a bond wire between hot and cold. I am not sure if it is a NEC requirement……….yet.
    Its to make sure the HW is grounded since there is plastic everywhere now.
    delcrossvMikeAmann
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,085
    It certainly is refreshing to see such attention to detail. Even the bonding wire is nicely shaped! Thanks 😊
    Yours, Larry
    mattmia2 Member Posts: 16,673
    Why a union on the expansion tank if it is small enough to unscrew?
    SuperTech
  • psb75
    psb75 Member Posts: 1,126
    I don't think those TPRV's are code compliant with all of those 90°'s in the piping and fittings beyond them.
  • Teemok
    Teemok Member, Email Confirmation Posts: 757
    edited October 2024
    Way better than this slop I found last week. The mixing valve controller transformer sits unmounted on top of the box, has never been functional in 4 years. Flues are poorly supported with intake Y's on their sides. The clay floor sink is acid mush. The tape shot shows the location between a cold main 4" tee and the 2" cold side tailpiece of the mixer. There should be a recirculation balance tee and a check valve there. Found the both vfd pressure booster pumps running at 100% making hot water with friction. The list could go on….. sorry I had to tell somebody. I feel better now. Regarding your post, it's nice to see those clean joints and the pipe insulation fitted so well, it doesn't even need any electrical tape!
    delcrossv
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,538
    "Salivatin' like Pavlov's Dog..." Rolling Stones Mad Dog
  • Mad Dog_2
  • ChrisJ
    ChrisJ Member Posts: 17,350
    @Alan (California Radiant) Forbes
    Have a look at what McMaster sells.
    Scroll down a bit to the fittings.
    That may not be what your guy used, but it could probably make your work look just as good.
    delcrossv
  • I see that. What a thoroughly nice selection. But I questioned him once about his materials and methods and he said it was all freehand and he’s not the kind of guy to embellish or stretch the truth. If you met him once, you would agree.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Having a union makes it easier. Having a plastic mitre box and a sharp 10" serrated knife is required for cutting neoprene insulation.
    MikeAmann
  • This one is not serrated, but it goes through insulation "like butter".
    https://www.amazon.com/gp/product/B0009MZI4W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    delcrossv
  • HomerJSmith
    HomerJSmith Member Posts: 2,774
    The difference between 'just so' and extraordinary is ART. The Japanese make an art out of pouring tea. I always look to symmetry (ART) in the work I do. I get great satisfaction from that. Funny, when I start a project, I have no idea where to start or how to do it. Some how, it always turns out beautiful (which is symmetry) and functional. It's like ZEN, it proceeds out of doing.
    delcrossvAlan (California Radiant) ForbesEdTheHeaterMan
  • hot1
    hot1 Member Posts: 9
    Incorrect insulation. Armoflex is for chilled water. Should befiber glass with asj
    delcrossvGGrossGroundUpJakeCK
    EdTheHeaterMan Member Posts: 12,127
    edited October 2024
    Really? So foam insulation will not insulate on hot water pipes, only on cold water pipes. This is interesting, I never knew that. 25 years ago I installed a combination chiller/boiler system that uses the same pipes for the cold water in the summer and the hot water in the winter. I never told him that they needed to change the insulation each season. Besides, I put all kinds of muck on that insulation to make sure the vapor barrier was sound so condensation wouldn't form under the insulation.
    That would be a really labor intensive changeover each season, Glad I'm retired and don't need to deal with that anymore.
    GGrossLRCCBJ
  • ChrisJ
  • tim smith
    tim smith Member Posts: 2,928
    epdm close cell is the good stuff rated for higher temps. The insul in OP photos is open cell I’m pretty sure and may only be rated to 160 but not totally sure on that. I’ve seen open cell melted to copper on 180 systems.
    ChrisJAlan (California Radiant) Forbes
  • ChrisJ
    I think you're 100% right.
    The texture and color don't look like what I think of when someone says Armaflex.
  • 8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
