Power vented oil boiler exhaust system question
tins
tins Member Posts: 3
Actually two questions. 1- Can a power vented oil boiler exhaust system be changed to a conventional flue system? The power vent system is causing a fume issue and we would like to know if it can be vented up the side of the house to above the roofline? 2- If not is there a in-line booster fan to achieve this?
