pex?
GW
GW Member Posts: 5,183
Got a boiler change, my estimator guy says he couldn't make sense of the wording on this tube, and I can't read it. Is this normal pex? I got jammed once on a Heatway job (poor flow), trying to be cautious. Merci Buckets
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • GGross
    GGross Member Posts: 1,850
    I can only make out the "F876/F877" marking on there which I believe is a pex ASTM number. If you have any slightly clearer pics of the tube maybe could make out more of it. Looks like pex to me though
    GW
  • GroundUp
    GroundUp Member Posts: 2,508
    The Nibco barrier tubing they used to sell at Menards had very similar gibberish on it and was the same color. I run into it quite a bit around here but I don't know if I have a chunk of it laying around or not, as they discontinued it probably 5-6 years ago. I'll take a look and see if I can find some. Is that 3/8"? Looks a bit smaller than normal.
    GW
  • GW
    I'll ask, this is a copy from the service titan program.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    It does seem to be smaller. Looks like 3/8 to me too.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    hot_rod Member Posts: 27,352
    watts has their own line of pex, the heat pex was orange. It does look to be 3/8
    At the PPI, Plastic Pipe Institute, website they explain all the various listing numbers. The ASTM is a dimension or tolerance spec, I believe
  • GW
    Good eyeball work thanks
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GroundUp
    I found some Nibco pex. Looks to be similar but not the same
    GW
  • GW
    looks like the man wants to go forward with us, I'll see it with my own eyes soon😊
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    GGross
