Compression tank: galvanized or painted?
delcrossv
Member Posts: 2,200
Replacing a old Thrush compression (no bladder) tank. I believe it's plain steel. Any issues with going with a galvanized tank? Or should I just go like for like.
Thanks!
don’t screw copper directly to galvanized metal. No glycol allowed in galvanized metal.
Does the tank have air tube fitting into it? B&G Airtrol as an example? An air purge fitting on the boiler?
Why not a diaphragm tank at a fraction the size and cost?
Living the hydronic dream1 -
Hat's off to Quality Tanks! Got my tank in ONE DAY after the local distributor said 3-5 days and "we don't sell a lot of those, just get it from the manufacturer". Sweet little 8 gal. tank.
https://qualitytanksinc.com/
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1
