The air bound heating system this fridays case
RayWohlfarth
RayWohlfarth Member Posts: 1,977
This weeks case is about a heating system I thought I knew well. We replaced a circulator and had to drain the system. The video will talk about what I discovered and other ways we found to dislodge stubborn air pockets. Seeya Friday @6am EST
Ray Wohlfarth
Boiler Lessons
    EdTheHeaterMan Member Posts: 12,127
    So… Just askin'. Did you add Isolation valves?
    OR
    Leave the same problem for the next guy!
    mattmia2 Member Posts: 16,663
    @hot_rod 's dish soap?
    EBEBRATT-Ed Member Posts: 20,144
    Pumping toward the ET instead of pumping away
  • RayWohlfarth
    edited September 2024
    @EdTheHeaterMan I added valves I would not want the next guy cursing me out
    @mattmia2 Dish soap? I will have to look that one up
    @EBEBRATT-Ed It was already doing that. but I found a secret weapon
    here is this weeks video.
    Ray Wohlfarth
    Boiler Lessons
    mattmia2EdTheHeaterMan
  • retiredguy
    retiredguy Member Posts: 1,090
    If you are highly regarded as an expert and friend of the customer, then you should recommend to the person in charge that they have the isolation valves around the pump rebuilt to save them time and money on future repairs. There are great local companies that can do this work.
    The increased pressure also increases how much air will dissolve in the water.
  • jumper
    jumper Member Posts: 2,533
    On bigger buildings it pays to evacuate air before filling. I used to ask big bucks$$ for this service and got few customers. Instead hours were spent bleed here, there, and everywhere.
    ethicalpaulRPK
