Compression tank: galvanized or painted?
delcrossv
delcrossv Member Posts: 2,203
edited September 2024 in THE MAIN WALL
Replacing a old Thrush compression (no bladder) tank. I believe it's plain steel. Any issues with going with a galvanized tank? Or should I just go like for like.
Thanks!
    EdTheHeaterMan Member Posts: 12,127
    Galvanizes will not hurt anything. Steal is also fine. Whatever you can get easily and economically.
    delcrossv
    pecmsg Member Posts: 7,039
    that old steel tank is what 50 years old?
    stick with steel.
    delcrossv
    hot_rod Member Posts: 27,413
    don’t screw copper directly to galvanized metal. No glycol allowed in galvanized metal.
    Does the tank have air tube fitting into it? B&G Airtrol as an example? An air purge fitting on the boiler?
    Why not a diaphragm tank at a fraction the size and cost?
    Big Ed_4
  • delcrossv
    All iron pipe. Has an Airtrol,so I'm good.
    I'm going with plain steel , in another 60 years I won't be in a position to care.
    PC7060
  • delcrossv
    Hat's off to Quality Tanks! Got my tank in ONE DAY after the local distributor said 3-5 days and "we don't sell a lot of those, just get it from the manufacturer". Sweet little 8 gal. tank.
    https://qualitytanksinc.com/
    hot_rod
