Special application for gas control valve
I developped an application for mobile hot water tank fired by propane burner . This obviously includes gas control valve. So no electricity is involved ( nor 110 V or 24 V) . But from local insurrance inspector I will need a LOW WATER CUT OFF ( lets say float type ) that will shut down the burner in case of low level .UNFORTUNATELY . i did not find any gas control valve with an auxiliary contact . Can any one help on this one ?
Regards
Mike
Ah… let me get this straight. You have a gas control valve of some kind — let's say as it might be an outdoor grille — which takes no electricity to operate. That's great. But… if it takes no electricity to operate, of what use is any kind of contact? A gas valve with a solenoid — the usual kind — requires electricity to operate that solenoid, and all that is needed is for the low water cutoff (and the other safeties which I hope you have) to cut off the power.
Am I confused?
Show us a few pictures, so we can get a better understanding of what you have.
Perhaps https://www.supplyhouse.com/Field-Controls-TCA-1-Thermocouple-Adapter-for-30-millivolt-Gas-Valve is what you're looking for?
2 -
use a millivolt valve and put the safety in the control chain for the valve. will have to use a float type lwco
although that will also kill the pilot in most applications which could be an issue if the float bounces or some other transient thing trips the lwco.
there is no electricity involved in the process . So there is no possibilty for gas solenid valve
Exactly what I want to do . But I did not find any milivolt valve that allows that
It does not matter . The user will have to start back the heater and keep on working . Not an issue for me
similar valve type but with auxiliary contact to connect LWCO float and/ or remote start push button
Thanks !!! , sound we are on a good track . I will look at the bulletin and report if this could be our solution
- 119 Chimneys & Flues
- 76 Pipe Deterioration
