Towel Warmer
My wife and I are traveling and have this towel warmer in our bathroom with supply and return piping and also an electrical connection. I believe there’s an electrical heating element that you can program to keep the towel warmer on during the summer.
Greening
  • ratio
    ratio Member Posts: 4,182
    Towel warmer? With a 20° setpoint, wouldn't that be a towel freezer?
  • JUGHNE
    JUGHNE Member Posts: 11,514
    20 degrees C is about 158 Fahrenheit.
    Alan must be out of the country.
    Greening
  • neilc
    neilc Member Posts: 3,137
    edited September 2024
    uh, 20c is a lot closer to 68/70f, than 158
    known to beat dead horses
    ChrisJGreeningGGross
  • JUGHNE
    Yes, you are right. I was reading the chart in the wrong direction……..that isn't a very warm towel.
  • It only gets lukewarm, just warm enough to heat the towels. Seems like a lot of trouble just to keep the towels warm, but different cultures take comfort seriously.
    HVACNUT Member Posts: 7,266
    It's taken quite (absurdly) seriously here too. I had an emergency service call in August for radiant heat not working in the master bath. Yes, it also is set for 68° cooling at the same time.
    Needless to say, their definition of emergency wasn't our definition of emergency, so we made warm tootsies on Monday. Then I peeled them some grapes, and bowed out gracefully.
    Hope you're having a blast, Alan.
    PC7060Alan (California Radiant) Forbes
