Gas control valve in water?
If water rises near the bottom of a gas control valve as shown below by the red line in a flood, is the valve considered submerged and is it compromised?
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,114
    Probably not, but no guarantees. Needs to be disconnected, drained, dried out...Another inch......A gas professional with experience shlupd be doing this...serious business Mad Dog 🐕
    partlyleft
    pecmsg Member Posts: 6,033
    Why take the chance?
    Change it out.
    partlyleftMad Dog_2
  • ratio
    ratio Member Posts: 3,974
    Depends, are you looking for legally damaged, or actually damaged?
    partlyleftMad Dog_2
    Steamhead Member Posts: 17,768
    Change it.
    Consulting
    Larry WeingartenpartlyleftMad Dog_2
  • partlyleft
    partlyleft Member Posts: 22
    edited August 2024
    Thermocouple, pilot and main out to burner were all immediately disconnected to remove burner assembly for drying.
    Except for what looked like some old pre-existing corrosion on thermocouple compression nut, No moisture or water noticed...
  • partlyleft
    edited August 2024
    "Actually"
    I see two little wires that look "pressed in" above the thermocouple connection. I'm wondering where/if there are orifices that would allow water entry on the unit.
    hot_rod Member Posts: 25,029
    the insulation in the tank must have gotten wet also?
    Salt water? How old is the tank?
    partlyleft
  • partlyleft
    edited August 2024
    The insulation did get wet but only soaked less than an hour or so.
    No salt water, living above 1000 ft.
    I immediately removed the burner assembly and blew it out thoroughly with compressed air.
    Tank is 11 years old.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,823
    Hi, If this is your own heater, it's your choice. If this were a client's water heater, you could not ethically subject them to the risk.
    Yours, Larry
    partlyleft
  • ratio
    I am not a lawyer, and you should certainly change the valve.
    If the water stopped where the line is, I wouldn't worry about it if it were in my house. If it were Grandma's house, or I was on the clock at work, I'd replace it.
    partlyleft
  • partlyleft
    edited August 2024
    Thank you. Yes it is mine.
  • partlyleft
    Can someone tell me what the typical and worst case scenario is when these gas valves are defective from flooding?
  • Mad Dog_2
    Dude...if your calling them "wires" you're not trained or qualified to be working on the gas valve. Not a DIY project. Mad Dog 🐕
    edited August 2024
  • partlyleft
    I have done my own remodel plumbing and installed a gas water heater before with professional sign offs.
    What am I supposed to call them, thermocouple spaghetti, leads?
    Larry Weingarten
  • JUGHNE
    JUGHNE Member Posts: 11,401
    Could they be wires to the "sparker" run by the clicker button on the gas valve to light the piolet?
  • partlyleft
    No they are coming from above the thermocouple fitting and run into the control unit.
  • Larry Weingarten
    edited August 2024
    Hi, Those wires likely go to a non resettable high limit.
    Yours, Larry
  • partlyleft
    edited August 2024
    Is that for transducer "over-voltage"?
