Using 2 of 3 ports
dkavitski
Member Posts: 2
Mitsubishi model MXZ-3C3oNAHZ4
3-ports Can use 2 of 3 ports.
1/2 x 1/4 Port A
3/8 x 1/4 Port B
3/8 x 1/4 Port C
Can I just use Port B and C or do I have to use A and B?
Should be able to use the ports in any combination. Make sure to wire the head to the correct terminals! There may be restrictions on the sizes of the connected heads vs the ports.
All manuals are available at
.0 -
Thank you for the reply and the link.
Only using 2 out of 3 ports also gives you a reduction in output.
Minis are specific to How many indoor heads and what style can be used with each.
Please check with your supplier concerning what combination are allowed and what connection ports to use / not use.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
