NYC Council bill being drafted for radiator inspection
2»
    Jamie Hall Member Posts: 27,400
    All I want to know is what massive new bureaucracy is New York going to create to inspect all this, where are they going to get in remotely competent people to go around and do it, and who is going to pay for it?
    Mad Dog_2Intplm.
  • ChrisJ
    ChrisJ Member Posts: 17,418
    edited August 2024
    Things like this are paid for by taxes, no?
    There's several very competent people who work in NYC right here on this forum.
    Let's not forget @Jamie Hall you yourself were once an inspector.
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,564
    Largesse.….Mad Dog 🐕
  • ChrisJ
    Perfect.
    See, Mad Dog just volunteered to do it for the greater good no charge.
    Problem solved.
    Mad Dog_2
  • dko
    dko Member Posts: 669
    edited August 2024
    The new required LL152 gas line inspections are not paid for by taxes.
    I don't see why this would be any different.
    Just a ton more paperwork to put a master plumber's name on file so they know who to try and stick it to when something does happen.
    This is a responsibility game. Yeah, safety too.
    Mad Dog_2
    I hate to say this, @dko , but any inspection has to be paid for by someone. If it's not indirect though taxes, it's direct to the property owner. Money, contrary to seemingly common belief, does not grow on trees, not is there any free lunch.
    Mad Dog_2
  • ChrisJ
    Actually……..it can
    Lumber is very valuable, especially a lot of hardwoods.
  • dko
    edited August 2024
    LL152 inspections are paid for by the property owners, the plumber may charge whatever they want. NYC just makes the inspection itself mandatory.
    Exempt are one- and two-family homes, and other buildings classified in Occupancy Group R-3. I would assume this will have similar exceptions.
    hot_rod Member Posts: 27,510
    I don't expect elected officials be steam or hydronic savvy. Actually it is more the lobbyists that make the decisions, politicians answer to them.
    We have industry input committees. Even an email is considered input. Anyone here can get involved.
    Or just complain about a broken system.
    Dain Hansen is Government Affairs director at IAMPO. His articles and columns in newsletters shed some light on how the system really works. He puts it in terms that a tradesperson understands. Without any political bias.
    There are always code and code change committees working at IAMPO if anyone is interested. Online meetings mostly.
    Mad Dog_2Ironman
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,996
    @CoachBoilermaker I was suggesting the connected pipe and radiator be looked at once a year. You could see and leaks or rust. The ones behind the walls would not fill the bedroom with steam Thanks
    @exqheat Yes sir great point
    Ray Wohlfarth
    Boiler Lessons
    Mad Dog_2
  • ChrisJ
    edited August 2024
    I have zero experience with larger systems.
    But on my own system in my home the pressure is so low I'd have no concerns at all about totally removing a vent and going to bed. I'm not even sure it would leak at all under 90% of conditions actually. On a really cold night, steam would get to that point and even then I don't know how humid it could make the room.
    If I were to loosen the nut on the radiator valve and leave it, I'd be more worried about the condensation leaking on the floor than anything.
    The point being, is such high steam pressure actually required to heat these larger buildings? Or is that actually the main problem that needs to be addressed? I could easily see steam pipes in a ship, train or power plant as being deadly if something fails. But space heating?
    Like I said, I have zero experience with larger buildings etc which is why I'm asking.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,604
    Of course high steam pressure is not required to heat these buildings. And we don't know that pressure was an issue in any of these tragedies. Every death is a tragedy, but I am only aware of four deaths, from radiator stream leaks, in the history of steam heating. I would venture to guess, that more people die in New York City from allergies to bagels and lox. But full disclosure, I do not have documented statistics to back up my claim.
    CLambChicagoCooperator
    sounds like opportunity knocking. The bill should require licensed plumbers perform the work
    Mad Dogs Ethical Steam Inspections
    Set it up with the Uber model
    1 hr travel, 2 hour minimum charge paid by credit card before you leave the shop
    A signed inspection report when the work paid in full
    Like home inspections, you don’t inspect hidden or buried in concrete piping
    Sounds like an interesting job, meeting people, seeing new things.
    Then a book deal in a few years 🤔
    Mad Dog_2Intplm.
  • Mad Dog_2
    Dan said the Steam displaced the oxygen in the room in some of those deaths. Mad Dog 🐕
  • GGross
    GGross Member Posts: 1,914
    If it is anything like the new random inspections in my county they will hire a less-than-qualified 3rd party on a contract basis who will just show up and say "yup that's a radiator, you pass" (or in my case backflow prevention and electrical panels. they passed a backflow at our building that didn't exist…. I installed it after but they still passed it) I am sure the best of intentions was behind this but once someone figures out they can make a ton of money that same someone will figure out how to make that money with less and less labor involved.
    Mad Dog_2CLamb
  • JohnNY
    JohnNY Member Posts: 3,371
    I deal with the repair and maintenance of high pressure steam and so that makes me kinda sorta a little more qualified than most people to guess at this answer: The high pressure steam lasts longer (remains steamy) under high pressure/temperature and that's why it's delivered in such a way.
    Once it gets in to the buildings, it passes through two pressure reducing valves to get it to radiator worthy values.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    ChrisJCLamb
  • ChrisJ
    You're also experienced in the area this bill is targeted at, I think. You have experience in the systems themselves, the buildings as well as the tenants and owners. The entire situation, so to speak. Far more than most of us.
    If I may ask, what are your thoughts on the subject?
  • JohnNY
    Hi Chris,
    I've been retained by the legal team defending the building in the Kuravsky case and so I'm not able to share my thoughts or concerns here. Sorry. One day, I will share what I know to be true and hopefully we can all learn something useful from this tragedy.
    -JC
    Classes
    ChrisJGGross
  • exqheat
    exqheat Member Posts: 218
    Some of you are trying to develop a monopoly for yourselves to be the only one qualified to change a vent on a radiator. This is a simple matter that requires minimal training for a competent super. Competent super is the problem. Required super training, along with hot water temp checks, bath mixing valves checks, electrical extension wire checks, smoke detector checks, door lock checks, window child safety checks, in addition to garbage schedules would help. The problem needs the simple solution, not a complicated coded money fest for a few.
    John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.
    Mad Dog_2
  • Mad Dog_2
    Oh ..you mean the same supers that often run the systems WAY over normal operating pressure? Among. Countless other no nos? And, whats wrong with cornering a niche market? Mad Dog 🐕
    GGrossariccio
  • GGross
    @Mad Dog_2
    It's almost as though the super should have proper training, maybe they could even develop a license that trained super could obtain. What a novel idea its amazing nobody thought of it before.
    CLambariccio
