Drop header
Hey all, we are installing two new steam boilers along with a drop header. The header consists of a 6 inch pipe caped at both ends. I will have both boilers connected at 6 inches away from the end, one at both ends and 2 steam outlets to the building 18 inches away from those. Also, I will have a drip leg c/w steam trap directly underneath boiler header connections. Does anyone see any issues with what I am planning to do.
That won't work right. Any water that the drip legs don't catch will travel toward the system take-offs.
The right way is just like we'd pipe a boiler. Start at one end of the header with your two boiler lines. Then connect the two steam mains, and end with a single drip leg. I'd make the drip leg 2". Pitch the whole header down from the first boiler connection to the drip leg.
Consulting3 -
That's correct.
Consulting0 -
Thanks for the advice.
sim, how is the condensate water returning to the boilers?
Thru a condensate tank which is vented to outside.
I call those the Mad Dog Bazooka Header. With a 6" Trunk line, go with a 2 1/2" drip minimum. Send us final results. Mad Dog 🐕
- 169 Indoor-Air Quality
- 50 Industry Classes
