DHW brass well failures
for the past year or two I’ve been replacing wells and aquastat on various hot water heaters no matter the source of domestic water. I just left a job that I replaced these a year ago, I replaced again! Any one else?
Dezincification?
why are you heating hot water
say again? My guess would be the client doesn't like cold showers?
I believe it was just a harmless joke at the pleonasm overlap
free gift, true facts, burning fire, false pretense, regular routine, armed gunman, tuna fish
dezincification? Check the ph of the water. Change to stainless or tin plated wells
https://www.canada.ca/en/conservation-institute/services/conservation-preservation-publications/canadian-conservation-institute-notes/dezincification-brass.html
Have you tried a different brand/manufacturer? There might be a foundry issue with the emersion wells you are using.
China sourced materials are known for not passing code. Had to reject a thousand feet of 1" black iron, that would not thread, too brittle and went to US Steel which worked; rejected Chrome shower arms also; could feel the thread grooves on the inside pipe wall, also weighed less than code approved. No one verifies import quality anymore. I could go own. With any well water system i use Stainless Steel for acidic water. Buy American no longer means made in America. John Deere just built a plant in Mexico. I have 30 year parts in my warehouse that will last 4 times longer than cheap imports. I'll bet most new materials will not meet code specifications today. Caveat Emptor
