DHW brass well failures
for the past year or two I’ve been replacing wells and aquastat on various hot water heaters no matter the source of domestic water. I just left a job that I replaced these a year ago, I replaced again! Any one else?
  • DCContrarian
    DCContrarian Member Posts: 1,477
    Dezincification?
  • george_42
    george_42 Member Posts: 123
    why are you heating hot water
    Jamie Hall Member Posts: 27,519
    say again? My guess would be the client doesn't like cold showers?
  • dko
    dko Member Posts: 669
    I believe it was just a harmless joke at the pleonasm overlap
    free gift, true facts, burning fire, false pretense, regular routine, armed gunman, tuna fish
    hot_rod Member Posts: 27,709
    dezincification? Check the ph of the water. Change to stainless or tin plated wells
    https://www.canada.ca/en/conservation-institute/services/conservation-preservation-publications/canadian-conservation-institute-notes/dezincification-brass.html
  • Intplm.
    Intplm. Member Posts: 3,069
    Have you tried a different brand/manufacturer? There might be a foundry issue with the emersion wells you are using.
  • Lance
    Lance Member Posts: 337
    China sourced materials are known for not passing code. Had to reject a thousand feet of 1" black iron, that would not thread, too brittle and went to US Steel which worked; rejected Chrome shower arms also; could feel the thread grooves on the inside pipe wall, also weighed less than code approved. No one verifies import quality anymore. I could go own. With any well water system i use Stainless Steel for acidic water. Buy American no longer means made in America. John Deere just built a plant in Mexico. I have 30 year parts in my warehouse that will last 4 times longer than cheap imports. I'll bet most new materials will not meet code specifications today. Caveat Emptor
