LNG TO FUEL A HAUCK STARJET BURNER
depeterson59
depeterson59 Member Posts: 1
Can anyone tell me LNG get converted back to vapor before being fired in a Hauck Starjet Burner at an Asphalt Hotmix Plant?
    Steamhead Member Posts: 18,495
    Not an expert, but since LNG is kept in its liquid state by cooling it, it would simply need to be warmed up to turn it back into its gaseous state. See:
    https://www.sciencedirect.com/science/article/abs/pii/B9780080999715000131
    Consulting
    Jamie Hall Member Posts: 27,359
    All "liquid" fuels have to be converted to a gas — vapour — before burniing. Even Bunker C. Some are easier than others! All you have to do with LP is drop the pressure on it. In an LP gas tank the vapour is in equilibrium with the liquid at a pressure well above atmospheric (at atmospheric pressure the propane part of the mix boils at -40, the butane at freezing — 32). Then the vapour goes through a regulator (sometimes two stages) which reduces the pressure to something manageable… and on to the burners.
    EBEBRATT-Ed Member Posts: 20,166
    I would call Hauck with any questions
  • retiredguy
    retiredguy Member Posts: 1,092
    Depending on the size of the LP storage tank, the input of the burner, and the ambient outside temperature, you may need to have an LP vaporizer in order to burn the LP correctly. All the large asphalt plant boilers I worked on that utilized LP gas were equipped with vaporizers.
    bburd
