Tekmar 256 and remote thermostat?
Hi everyone,
Wrapping my head around the Tekmar 256 boiler control for my Hydronic heating system with fin-tube convectors.
Currently the 256 uses the outdoor reset sensor as well as a sensor that is "taped" onto the supply pipe near the boiler.
This is a 4-family, 2 story building. Is there any benefit to haveing another sensor somewhere else in the building? Or a sensor on the return?
Thank you!
thank you! Yes, one zone. The 256 turns on/off the boiler. ExternaL Outdoor reset and pipe sensor.
Do you think I would need another type of boiler control with inputs for a indoor sensor?
Is the heat always on with no indoor t-stat. You could always add a t-stat located in the mech room with a remote indoor sensor. Tekmar make several models that can do that.
Albert Einstein0 -
think of the wall thermostat as a high limit temperature device.
A thermostat could mount anywhere in the building as long as the temperature sensor is located in the room that you want temperature control, or limit.
A well tuned ODR could keep the boiler and call for heat running almost continuously. If everything is sized and dialed in properly.
Living the hydronic dream2 -
Thank you, Hot Rod. Are there any resources or tips of your own to optimize the outdoor reset?
- 120 Geothermal
