Oil Leak after tune up
Traveler1245
Member Posts: 2
in Oil Heating
A guy came over to do a tune up which included a filter change and nozzle change, now there is a leak from the oil burner. What could this be from? It was not leaking before this.
Ah… to do the nozzle change, the oil lines have to be disconnected… and someone didn't get something put back together properly.
Could it be that the nozzle is loose? Or the filter is sucking in air? These are things I read when I did some research
Call them back.
Consulting6 -
The stem on the firomatic valve at the burner looks short meaning the valve may not be all the way open.
Check under the cover maybe the piston is leaking , it happens with age….Good burner….
