Oil Leak after tune up
Traveler1245
Traveler1245 Member Posts: 2
A guy came over to do a tune up which included a filter change and nozzle change, now there is a leak from the oil burner. What could this be from? It was not leaking before this.
    Jamie Hall Member Posts: 27,513
    Ah… to do the nozzle change, the oil lines have to be disconnected… and someone didn't get something put back together properly.
  • Traveler1245
    Could it be that the nozzle is loose? Or the filter is sucking in air? These are things I read when I did some research
    EBEBRATT-Ed Member Posts: 20,387
    The stem on the firomatic valve at the burner looks short meaning the valve may not be all the way open.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,545
    edited June 2024
    Check under the cover maybe the piston is leaking , it happens with age….Good burner….
