Repair or Replace Buderus GB142-60
Hello - I have a ~18 year old Buderus GB142-60. Our current HVAC service company has said our boiler is essentially at end of life and not worth repairing anymore.
We started getting some quotes to replace it, but even the cheapest replacement option is going to be quite expensive. In looking at the price of parts online, it seems that even if we have to replace the heat exchanger at some point soon, it will still be much cheaper than installing a new boiler. However, after contacting a few companies, they all just want to jump right to replacing the boiler rather than trying to keep it running.
Are there any repair technicians that you would recommend in the Boston area who are experienced with Buderus boilers and skilled at doing repairs to keep them running?
If this is steam, talk to @New England SteamWorks
Thanks - I understand this boiler is past its useful life but the replacement quotes I have gotten are shockingly expensive ($-$). Assuming a lifespan of 20 years for the new boiler and the middle of that price range, a new boiler is essentially $ per year. So, I am kind of looking at that as my threshold for a repair cost above which I would pull the trigger on a new boiler. I guess the conclusion that leads to is if a needed repair is beyond my DIY skills and an expensive part (e.g. replacing the heat exchanger), I should just get a new boiler installed at that point.
@Jamie Hall - this is hot water not steam. Any suggestions for a good hot water boiler company in the north shore area of Boston?
I just put a new fan in a 17 yr. old Buderus GB 142-45. It has given good service. I have spent a fair bit of time cleaning concretions out of it. It is still going. I expect to replace it in the near future. I expect to pop a good new mod-con boiler in its place for less than 1/2 the money you mention.
it’s a labor intensive job, contractors want to save their energy for full boiler jobs with larger margins.
i missed your dollar signs before it was wiped out. Shoot me a message with some basic budget goal and perhaps I can make a drive. I’m 2 hours away. The Bostonian contractors get yuge dollars0 -
@GW2 - Thanks, I sent you a message!
@psb75 - Thanks for that data point.
@kcopp - Sorry about that! The boiler has a slow leak from the air vent that I noticed for the first time a few weeks ago (may have been happening for a while, not sure). In addition, this week, the boiler started having the occasional 6a error code which I have been able to clear by resetting the boiler. Approximately 1 year ago, I had the same error code which eventually required a new ionization electrode and ignitor.
That is a replaceable part, No reason you cant fix that and get more time from it.
@ThinLandscape620 , I’m in almost the exact same predicament as you and am also in MA on the coast near NH. I just had the igniter replaced but due to leaks and heat dropping out forcing me to go in the basement regularly to tweak the valve on the expansion tank. Everybody wants to sell me a new system while I’ll wondering if only the heat exchanger and/or the expansion tank need attention. The company which installed it 12 years ago sells oil and gas no longer want to work on it. What did you end up doing? Does anyone have any suggestions? Biting the bullet and replacing the unit feels wasteful and is very expensive. Of course they offer 18 month no interest financing but I’d like to spread it over a longer time horizon.
When you say tweak the valve on the extrol tank…you mean add water to the system?
If the block is leaking you are only a matter of time before its done. I personally would not replace the HX. Its time for a new boiler.
I have a couple out there that still are not leaking. I have replaced the fan and a few other components. Im pushing them off till the repair parts are not around any longer.
- 50 Industry Classes
