Underslab Plumbing
It was only because my daughter and son-in-law asked me to do this work for their ADU that I agreed to take on this work, but I was pleasantly surprised that at my age, I was still able to do it.
Shower in the back, then the toilet followed by the lavatory and then the sink drain off to the left.
Tell me more.
Thanks, @MikeL_2. That makes a lot of sense and seems like a practical thing to do.
As you can see, I installed a 2” drain for the lav because I’ve had to snake too many clogged lav drains before.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Alan,
I've discovered 100's of dry horizontal vents below fixture flood levels in my 50 plus year career; mostly on tub & shower drains. And more than half of those vents were plugged with hair, soap scum, & other organic matter.
In my experience there are way more less than ideal vent connections on tubs & showers; only about 10% are ideal. It's so interesting because there's always a way to be code compliant. I don't asign fault or blame because the installers were probably taught to do it that way......
A toilet with a bidet and 3 inch trap would reduce clogging. I don't remember which brand it is but it has a 4 inch water port in the tank above the 3 inch trap.
On High Rise buildings We'll use a Drinking fountain waste stack to "wash" the multi-story vent stack . Mad Dog
Either way is good. I often do it the way you did @Alan (California Radiant) Forbes upping the diameter of the drain pipe is a great way to go.
Curious why the toilet has it's own 2" vent when the shower vent is right there?
California is under UPC code no?
is the shower vent a wet vent with a sink connected to it. if not it is against code.
What code says that?
cell # 413-841-6726
@Alan (California Radiant) Forbes Is it standard procedure in your area to install the piping so high then back fill? We need to leave as much in the trench as we can in Mass. I also have seen nightmares when GCs back fill so I always show up on back fill day.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
international plumbing code
@mikedo I haven't seen that in IPC I only have Massachusetts code on hand right now. Could you show me where in IPC it says that? I love learning about other areas codes.
cell # 413-841-6726
I think a new rule or decorum here should be if you're going to cite code you should post a screenshot of the actual code or copy and paste the text and the location it applies to.
This avoids any confusion and helps others learn.
This is common in electrical groups and honestly I feel it's very beneficial to everyone.
2 -
cell # 413-841-6726
ill try to find it and post it. maybe some one can show me in a code book its legal
@mikedo did you read the IPC screenshot I posted?
cell # 413-841-6726
yes where does it say it can go horizontal before tying in bestto post pictures from a codebook
tying into vent sorry about the typo
I like to indivually vent fixtures, but Wet Venting get very creative and fun. When I began in the mid 1980s, I did my apprenticeship in NYC code. "All fixtures shall individually vented within two feet of the trap. It was simple and worked perfectly. After Stony Brook, I worked for R.S. English on Long Island, so then I learned Wet Venting. My Master Plumbers Exam was on NYS Code...tons of Wet venting.
Now, even NYC code allows limited Wet venting. It's all good. Mad Dog
nothing wrong with indivually venting every fixture fixture guaranteed to work. vents is probally one of the most misunderstood chapters in the code book. it can just save so much time if you vent a 3 piece bath with a single vent instead of 3. im not as good as i used to be with the venting i dont do it as much anymore. really helps if you get a code book with the commentary but there expensive. nyc has their own way of doing things and im not familiar wiyh there codes
I've found the most roughing mistakes are made by guys that don't understand the principles of venting. Yes, Code with Commentary is an excellent study guide. When I sat for my Master Plumber exam in 1998, I took that thin typing paper you could see through and traced out ALL the venting diagrams: Circuit, Loop, Island, unit, local, backvent, trombone vent, stack vent, wet vent.
That helped me memorize how they were piped. Then I just mimicked them over & over until it was burned in my brain. Mad Dog
@Mad Dog_2 we both took our master exams the same year lol. Do you wish you took yours earlier? I know I wish I took it the first year I was eligible instead of procrastinating.
cell # 413-841-6726
in Massachusetts you could have wet vented the whole bathroom. Most bathrooms are wet vent in Boston and the surrounding areas and its saves a lot of time. it's the preferred method as old construction is very prohibited. a lot of these old homes on the east coast are not easy to get the piping in.
2 -
what code book does mass use for residental single family homes
California code is more forgiving than Mass as well.
I took the exam just as I had the 7 yrs W-2s, under a Licensed Master Plumber. I took a 5 year detour for College after my 4 yr apprenticeship. I free-lanced for plumbers, ran a PT Sewer & Drain business during College. I was 31 was I got my Plate. Mad Dog
i live in connecticut and have a p1 and s1 the s1 is for hvac they are both unlimited contractors. the state of connecticut does virtually nothing to enforce the need for a licencse. you cant get a permit without it but that doesnt stop the hundreds of thousands of people working without one. my friend just left californa only the owner needs a licencse so the unions are slow because unskilled people are willing to work for alot less. so not sure it was worth the time and effort to get it.
Unfortunately, licensing only puts the burden on the legit guys, financially, and punitive. Unlicensed & Ininsured guys run amok with impunity. There's nothing to take away from them..Mad Dog
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
