Bronze pipe adapter
Hello all,
I have two pipe steam. I recently had a radiator sandblasted and repainted. When taking it off of the system, the return side had a 1/2" NPT male to female fitting to extend the reach of the return to the steam trap. Almost seemed like the pipes were placed just a little too far apart (the age of the radiator makes it likely it is original). This fitting was bronze and it was damaged when removing it from the radiator.
I'm having trouble finding a replacement. The prime buy link below shows a brass version of what I need. Local hardware stores only have it in brass as well. My understanding is brass cannot be used in steam systems. I've also looked at other designs like the cast iron one in the McMaster Carr link below but the body is too long.
Any ideas?
https://primebuy.com/product/tompkins-industries-3200-08-08-pipe-expander-extender-1-2-x-1-2
No reason that I know of, not to use brass. Shut off valves are always brass. Pigtails are brass. Drain valves are brass..
brass steam radiator valves are common
Can you post a picture of the damaged fitting? Does a magnet stick to it?
Damaged fitting is no longer around. It was cracked from overtightening of the softer metal.
My understanding of brass is the water can de-zinc the material leaving a very porous and brittle metal. Maybe at low pressure not a big deal?
Only if the water is really acidic- and then you'd have other issues. . Brass is fine.
You got Bad Information. Brass & Bronze have been used on steam systems since it's inception. The Old US Navy ship engine rooms were loaded with them. Mad Dog
You can use black malleable fittings, Cast Black fittings, brass or even copper (last choice) if it's the only way to get it together. Mad Dog
- 117 Geothermal
