Bronze pipe adapter
nlongworth2
nlongworth2 Member Posts: 13
Hello all,
I have two pipe steam. I recently had a radiator sandblasted and repainted. When taking it off of the system, the return side had a 1/2" NPT male to female fitting to extend the reach of the return to the steam trap. Almost seemed like the pipes were placed just a little too far apart (the age of the radiator makes it likely it is original). This fitting was bronze and it was damaged when removing it from the radiator.
I'm having trouble finding a replacement. The prime buy link below shows a brass version of what I need. Local hardware stores only have it in brass as well. My understanding is brass cannot be used in steam systems. I've also looked at other designs like the cast iron one in the McMaster Carr link below but the body is too long.
Any ideas?
https://primebuy.com/product/tompkins-industries-3200-08-08-pipe-expander-extender-1-2-x-1-2
https://www.mcmaster.com/product/44605K312
mattmia2Mad Dog_2
    Jamie Hall Member Posts: 27,014
    Somebody? Anybody? What is the rationale behind not using brass in a steam system? I can't see why not…
    And a bronze fitting is going to be pretty well unobtainable.
    Mad Dog_2
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,550
    No reason that I know of, not to use brass. Shut off valves are always brass. Pigtails are brass. Drain valves are brass..
  • Waher
    Waher Member Posts: 369
    edited May 2024
    brass steam radiator valves are common
  • JUGHNE
    JUGHNE Member Posts: 11,527
    Can you post a picture of the damaged fitting? Does a magnet stick to it?
  • nlongworth2
    Damaged fitting is no longer around. It was cracked from overtightening of the softer metal.
    My understanding of brass is the water can de-zinc the material leaving a very porous and brittle metal. Maybe at low pressure not a big deal?
  • delcrossv
    delcrossv Member Posts: 2,189
    edited May 2024
    Only if the water is really acidic- and then you'd have other issues. . Brass is fine.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,469
    You got Bad Information. Brass & Bronze have been used on steam systems since it's inception. The Old US Navy ship engine rooms were loaded with them. Mad Dog
  • Mad Dog_2
    You can use black malleable fittings, Cast Black fittings, brass or even copper (last choice) if it's the only way to get it together. Mad Dog
  • pedmec
    pedmec Member Posts: 1,284
    Someone gave you bad info. radiator valves and thermostatic traps are both made from brass.
    Mad Dog_2
