American Standard EP-82 Electric Boiler
msundstrom
msundstrom Member Posts: 3
Looking for a sequencing switch for my 1976 AS EP-82 electric home heating boiler. Not sure where to look, my standard searches have not found anything on this.
Thanks
Mark
    hot_rod Member Posts: 26,045
    A good chance it was built by some one else. Any other names on it, EFM maybe. Or a part number on the sequencer? Got a pic?
  • msundstrom
    heater sticks on until I tap on the sequencer. I haven’t removed it, trying not to unless I have too
    Jamie Hall Member Posts: 26,597
    Well… you have the maker (Honeywell) and the part number. That's something. However, at something like half a century old, you may find that it dropped out of production a few decades back.
    It looks like a mechanical contactor, however, of some kind, and if it is possible to get it apart (don't break anything) it is also possible that the contacts could be refurbished…
    EBEBRATT-Ed Member Posts: 18,951
    Honeywell used to use a mechanical sequencer like that on large roof top units they are unavailable now.
    Everything now is electronic.
    I am sure there is something available, but it won't be a drop in replacement. It will probably require some rewiring and the new controls may not fit in the control panel, but it can be done. Can you post a wiring diagram if it exists.
  • msundstrom
    it has 5 heating elements
    24 volt from the thermostat starts the sequencer. It is going to be tough to find something with 5 stages that is why I am wondering what size the heaters are. Maybe we could make it 2 or 3 stage?
    I have a bd feeling whatever I come up with will be expensive. Could probably do it with 24v time delay relays and some relays or contactors but it will be a bit of rewiring.
    Do you have any idea of on a call for heat how quickly it goes from stage 1-5?
