Oetiker SS clamp and appropriate coupling should fix that.
Merflex PEX
Member Posts: 4,381
Does anyone know if this is PEX A, B or C? Can Uponor expansion fittings be used as this Sharkbite fitting has failed.
Have always had bad luck with that joining method.
Odd. I haven't. But what @kcopp says above about Viega. They are the other type I use. Mostly use with great results and should work in replacing the shark bite.
@Alan (California Radiant) Forbes Can you tell what made the shark bite fail?
I haven’t been to the job yet, but they probably nicked the o-ring when it was installed or it wasn’t inserted all the way.
Two btu per sq ft for degree difference for a slab0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 961 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
