Merflex PEX
Does anyone know if this is PEX A, B or C? Can Uponor expansion fittings be used as this Sharkbite fitting has failed.
Oetiker SS clamp and appropriate coupling should fix that.
Have always had bad luck with that joining method.
I really like the press sleeves that Viega makes.
https://www.supplyhouse.com/Viega-93020-Zero-Lead-Bronze-1-2-PEX-Press-Coupling-w-Attached-Sleeve
Odd. I haven't. But what @kcopp says above about Viega. They are the other type I use. Mostly use with great results and should work in replacing the shark bite.
@Alan (California Radiant) Forbes Can you tell what made the shark bite fail?
I haven’t been to the job yet, but they probably nicked the o-ring when it was installed or it wasn’t inserted all the way.
Two btu per sq ft for degree difference for a slab0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
