Merflex PEX
Member Posts: 4,381
Does anyone know if this is PEX A, B or C? Can Uponor expansion fittings be used as this Sharkbite fitting has failed.
Oetiker SS clamp and appropriate coupling should fix that.
Have always had bad luck with that joining method.
Odd. I haven't. But what @kcopp says above about Viega. They are the other type I use. Mostly use with great results and should work in replacing the shark bite.
@Alan (California Radiant) Forbes Can you tell what made the shark bite fail?
I haven’t been to the job yet, but they probably nicked the o-ring when it was installed or it wasn’t inserted all the way.
Two btu per sq ft for degree difference for a slab0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
