What time of year is acceptable to Shut Off steam heating system?
RTW
Member Posts: 255
I use my heat whenever I need it. I go by temperature not the month.
I don't care if it's July, if the house is chilly the boiler's getting fired up.
Same goes with air conditioning. If it's February and the house is too hot I'm cooling it down.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
It's not Germany...The Hydronic Police won't be knocking on your door. Use heat when you're cold. Mad Dog2
I see this quite often for schools mostly where they will have a set shutdown date so they can start maintenance and replacement work.
Now, what that date is............??Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
April 15 to October 15 is the law for landlords in NJ.
Years ago, and maybe still today, October fifteenth was the heat on institutional date.0
From the New York Tenants Rights Guide at: https://ag.ny.gov/sites/default/files/tenants_rights.pdf
Heating Season
Heat must be supplied from October 1 through May 31 to tenants in
multiple dwellings. If the outdoor temperature falls below 55°F between
the hours of six a.m. and ten p.m., each apartment must be heated to
a temperature of at least 68°F. If the outdoor temperature falls below
40°F between the hours of ten p.m. and six a.m., each apartment must
be heated to a temperature of at least 55°F. Local regulations may
require higher temperatures during these times. (Multiple Dwelling
Law § 79; Multiple Residence Law § 173; NYC Admin. Code § 27-
2029).
I believe this applies throughout the state, not just in NYC.1 -
Must be heated to? or must be able to be heated to? No wonder people ask how to turn off the heat... or open windows.Br. Jamie, osb
That's where TRV's become magical in my opinion.Jamie Hall said:Must be heated to? or must be able to be heated to? No wonder people ask how to turn off the heat... or open windows.
A huge building, tons of tenants, many don't want heat.
I'd bet the biggest issue with TRV's and end users is they probably don't realize you don't turn them several numbers for a difference. If it's set on #3 you go to 2.5 or 3.5 and wait a while and see what happens. If the apartment is a bit too warm just turn it down a very tiny tiny amount and wait an hour.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The power of steam. HeatThemUp !
As an aside, I found this article - and many like it - that discusses how the body reacts to the same temp in Fall vs Spring. It may explain why many turn down or off the heat sooner in the Spring, but just the opposite in the Fall
Regards
RTW
Beginning of ARTICLE dated Sept:
Why a 65-Degree Day Feels Cold in Fall but Warm in Spring
When seasons change, our bodies know to react. But we can perceive the same thermometer reading differently at various times throughout the year.
September 8, 2016 7:00 AM
Author
Kevin Joy
With temperatures set to drop in the coming weeks, you might be surprised to perceive a moderate, 65-degree day as chilly, whereas the same scenario in the spring would feel positively tropical.
There's a reason for that.0 -
The problem with TRVs Chris, is that if the boiler never shuts down or for not long enough periods, the TRVs will not work. Mad Dog
1
- 62 Biomass
