What is this and should it be this dirty
linus
Member Posts: 1
Clearly I don’t know about the mechanics of radiant heaters. Basically, just wondering what this is and if it should be cleaned. I’ve had so much maintenance on the radiant heater in my garage. I don’t want to call anyone if it’s not necessary. Thank you
Looks like a condensate trap, and it should be cleaned out. Some dirt is normal.Br. Jamie, osb
Easy enough to clean, don’t lose the o ring, or black rubber ball that is insideBob "hot rod" Rohr
Living the hydronic dream0
