What is this and should it be this dirty
linus
linus Member Posts: 1
edited April 2024 in Radiant Heating
Clearly I don’t know about the mechanics of radiant heaters. Basically, just wondering what this is and if it should be cleaned. I’ve had so much maintenance on the radiant heater in my garage. I don’t want to call anyone if it’s not necessary.  Thank you
    Jamie Hall Member Posts: 27,421
    Looks like a condensate trap, and it should be cleaned out. Some dirt is normal.
    hot_rod Member Posts: 27,559
    Easy enough to clean, don’t lose the o ring, or black rubber ball that is inside
