Laars mini therm soot
Elpisador
Elpisador Member Posts: 1
I have a Laars mini therm jvs125boiler about 10 years old. Had to clean soot 3 times over the last winter. Unit cycles on-off after a few seconds of firing up. Sometimes I get a buzzing sound. Any help is greatly appreciated. Thanks in advance.
    Jamie Hall Member Posts: 27,243
    Combustion is off. Get a competent tech. in there to thoroughly clean it, and with the proper test instruments and get everything set as it should be for best combustion. It is impossible to set a burner correctly by eye or by ear.
    kcoppSTEAM DOCTOR
    hot_rod Member Posts: 27,332
    Short cycling and low return water temperature are a couple causes of copper tube boilers sooting up.
    Things get worse as the fins plug up.
    Get a CO meter near that beast.
    EBEBRATT-Ed Member Posts: 20,085
    Yes, HX probably plugged with soot.
  • HomerJSmith
    HomerJSmith Member Posts: 2,774
    How's your combustion air?
