Laars mini therm soot
Elpisador
Member Posts: 1
in Gas Heating
I have a Laars mini therm jvs125boiler about 10 years old. Had to clean soot 3 times over the last winter. Unit cycles on-off after a few seconds of firing up. Sometimes I get a buzzing sound. Any help is greatly appreciated. Thanks in advance.
Combustion is off. Get a competent tech. in there to thoroughly clean it, and with the proper test instruments and get everything set as it should be for best combustion. It is impossible to set a burner correctly by eye or by ear.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England2 -
Short cycling and low return water temperature are a couple causes of copper tube boilers sooting up.
Things get worse as the fins plug up.
Get a CO meter near that beast.Bob "hot rod" Rohr
Living the hydronic dream0 -
Yes, HX probably plugged with soot.0
How's your combustion air?0
