Trane Furnace
camiarrobino
camiarrobino Member Posts: 83
Is a Trane 95% A951X060BU4SAB furnace a good furnace?
    pecmsg Member Posts: 6,893
    Only as good as the contractor that sized it and installed it.
    BillyWillEdTheHeaterManOldManwithStick
  • John Mills_5
    John Mills_5 Member Posts: 952
    It's a RunTru or Ameristar, lower end Trane and American Standard units.
    EdTheHeaterMan Member Posts: 11,755
    From reading the specifications and other documents, this is the entry level (or economy) furnace. It is made to minimum specifications and the price shows it. If however you have a qualified installer that knows what they are doing, you will find this piece of equipment to operate satisfactorily. You may spend a lot more on the premium furnace, and have it installed by a total idiot, and find that the more expensive offering is a piece of junk. Not because of the way it is built, but because it was not installed properly. That is why it is always better to have a good reliable contractor that stands behind the work they do, and forget about the name brand or equipment reputation.
