Radiator valves on Weil-McLain ECO 155 boiler system
My house is 116 years old and appears to have the original radiators in each room. It seems that none of the shut-off valves have any rubber left on their stoppers, because I can crank the handle closed with no effect on the radiators' heat output, and I don't feel any "give" whatsoever when the valve supposedly "seats" the rubber.
The supply and return pipes on the radiators have a 1" outer diameter threaded pipe. Am I correct in assuming I need to order 1" FIP & Male Union Hot Water Radiator Valves? I just wonder if the Outside Diameter or the Inside Diameter is used when referring to pipes and valves.
I also do not understand why I apparently have a hot water boiler (as opposed to steam), but all of my radiators have what appears to me to be a STEAM bleed valve at the top (see attached image).
The radiators are stamped "American Radiator Co" on the end.
For replacement valves, I'm considering Matco-Norca, Marsh or the cheap one, Bluefin. I prefer high quality and made in the USA over low price. Any recommendations?
That valve you pictured is a bleeder valve for a hot water system.
The pipes are sized by the nominal inside diameter.
The spud in the radiator is matched to the valve, you will have to replace the spud in the radiator with the valve and they usually don't come out easily.
You could likely put a new washer and packing in the old valves.1 -
Here are photos of one of the valves in question.
hmmm... well, easy enough to repack if they are leaking around the stem, but somehow I have a feeling that getting the bonnet off to get at the washer and seat might be a bit difficult. Might not, too -- they may be all brass, in which case they will at least not have rusted together... just a lot of paint sealing them.Br. Jamie, osb
I'll try to get some paint remover and very carefully brush it on the valve. I'll try very hard not to get any on the working mechanisms. Then we'll see better.0
- 120 Geothermal
