Atmospheric conversion burner?
I know Carlin, Beckett etc, make power conversion burners, but I can't find any atmospheric version poking around on the web.
Question is, does anyone still make an atmospheric conversion burner as a kit? Seems there'd be a market for it with no fan noise to deal with.
Not that I know of.
I think making an atmospheric work in a modern oil-fired boiler would be a lost cause. There is not enough of an opening to provide the needed combustion air by natural draft, so you would need a fan.
What boiler do you have?All Steamed Up, Inc.
Consulting0 -
Not enough of an opening in the burner door? How did they handle it previously? The ones I've seen fit in a 5 or 6" port in the firebox door w/o any additional air input.Steamhead said:Not that I know of.
Sort of a general question at present. But something like a PeerlessWBV or BurnhamV8H, WM WGO or similar. Wet base.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
You might look at Midco or Roberts Gordon but I don't think they are made any longer.0
they were really just used for coal conversions. not much of a market for that anymore and you can make a gas power burner work when you can make an atmospheric burner work so no reason to make 2 products. i think the few that i have seen in person were bryant.0
Customers didn't care about electric consumption?0
And they're noiseless.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Last I saw was on a Crane, and it really looked like it was made for oil- no provision for a grate or ash box.mattmia2 said:they were really just used for coal conversions. not much of a market for that anymore and you can make a gas power burner work when you can make an atmospheric burner work so no reason to make 2 products. i think the few that i have seen in person were bryant.
Kept on poking around and finally found this! 50,000 to 290,000 btu adjustable. Atmospheric.
Seems just the thing when you have a tenant right above the boiler room.
https://adamsmanufacturing.com/gasburners.html
Fixed the link:
https://www.adamsmanufacturing.com/pdfs/speedflame2.pdf
The diagram does not show the air tube diameter, and I can't find the installation manual on the site.All Steamed Up, Inc.
Consulting1 -
Thanks!Steamhead said:Fixed the link:
Me neither. I'm going to call them Monday and see how big a hole in the door I'd need. But looks like an updated version of the ones I've seen.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
What boiler do you want to put this in?All Steamed Up, Inc.
Consulting0 -
Nothing specific , yet. But a wet firebox, large water volume one is what I'm thinking.Steamhead said:What boiler do you want to put this in?
@Steamhead Any suggestions in the 80-150k BTU range?Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Our fax was having problems so they're mailing it. I'll try to scan up the relevant pages when it comes in.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
If that burner has no fan at all, pretty much any modern boiler's flue passages will probably cause enough back-pressure that you won't get good combustion. I'll wait to see what the manual says about it.delcrossv said:
FWIW, the Midco EC series burners are a bit quieter than the Carlin EZ-Gas. We've used both.All Steamed Up, Inc.
Consulting0 -
@delcrossv
I would be extremely cautious about installing Anything that Adams makes. We (when I was working) installed some of their furnaces...nothing short of junk.
If you search on this site for a post, I did 6 or 7 years ago you will see the problems I went through.
If their gas burner are anything like there other equipment I wouldn't touch it.
But that is up to you.1 -
I personally have never installed a conversion gas burner with atmospheric draft. I really like Carlin EZ Gas with a 9 slot head. I learned a valuable lesson years ago on conversion burners. I have a system that had 3 Axman Anderson NPO oil boilers to convert. I called Axman for a burner recommendation on what gas burner to use.
I installed the burners as per instruction. I noticed there seemed to be a delay in the ignition and it would light very hard at times. I called the factory and actually talked to the owner / designer. He asked me about draft. I had plenty of draft. He had me put the test kit on. He was thinking that I was on the wrong side of the combustion curve. After more adjustments, we lit it off and I swear, I ran for the door. Thought it was blowing up. It actually jumped around the pad. Scared the hell out of me. We ended up switching burners. I won't throw stones at any manufacturer, but I will tell you when we switched burners, it was 100% improved. The problem ended up being the head that came with the burner. They recommended a 9 slot head. They fire with a swirling action which is perfect for a horizonal pass type boiler. The combustion gasses are not loading up the chamber causing a lack of combustion air and poor combustion.
AA boilers are made in my home town so there are a lot CP0s around and many want gas. I don't think any kind of atmospheric burner would work well with horizontal pass boilers.
I was surprised to see the efficiency rate of these converted boilers. Solid mid 80s on just about all of them. Good luck
@EBEBRATT-Ed Looking through old posts. Thanks for the warning. Was that one of their condensing oil furnaces?EBEBRATT-Ed said:@delcrossv
Looks like Superior Boiler/Triad specs their burner as OEM. (???)Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Curious as to which burner you ended up using?Mustangman said:I personally have never installed a conversion gas burner with atmospheric draft. I really like Carlin EZ Gas with a 9 slot head. I learned a valuable lesson years ago on conversion burners. I have a system that had 3 Axman Anderson NPO oil boilers to convert. I called Axman for a burner recommendation on what gas burner to use.
Consulting0 -
Believe it or not, it was the first Carlin EZ gas I installed. Its pretty much the only conversion burner I use. You have to order them with a 9 slot diffusers. Carlin has worked well on just about every brand and model out there . Add in the experience I had, hands on, when I thought judgement day was here for me... I will stay with Carlin. I have installed Midco gas conversion burners and Wayne. Both good units. I can tell you the Wayne gas conversion is the one I couldn't to run on a an Axman horizonal tube boiler. I really believe the issue, has to do with timing. I will save what I learned for another time as its a bit long winded.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
