Steam pipe style convectors
todd_ecr
Member Posts: 92
Are they 1.5" SCH 40 pipe, or actually 1.5" OD?
1.5" SCH 40 pipe would be 0.497 sq ft EDR per 1' of pipe
If it's actually 1.5" OD that would be 0.393 sq fr EDR per 1' of pipe
That's a pipe-coil radiator. I know there are charts for these but didn't see them in the site's Heating Museum. I'll keep looking, as I'm sure all the Wall regulars willAll Steamed Up, Inc.
Consulting0 -
That's amazing
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Dan's Books have all these formulae. Start your essential library ✨️ today! Mad Dog 🐕2
So,KC_Jones said:Are they 1.5" SCH 40 pipe, or actually 1.5" OD?
Roughly 180sqft EDR?
I'd like to see an IR video of that heating up. I wonder if the whole thing heats up or just one or two of the pipes
If each pipe is 60', and it looks like 6 of them, then yes 180 should be the number.ChrisJ said:0 -
why are there vents everywhere if it is 2 pipe? or is it 1 pipe with a condensate return below the water line or to a water seal or something like that?0
It also really should only need one big vent down where that ell and nipple is at the bottom.0
Looks like a 2-pipe air-vent system- pre-Vapor.mattmia2 said:why are there vents everywhere if it is 2 pipe? or is it 1 pipe with a condensate return below the water line or to a water seal or something like that?
Consulting1 -
I've seen this at a Church in Manchester, NH. Much of the pipes were patched with clamps and rubber. The building was built in the late 1800's.
I actually proposed a replacement boiler and to replace the piping or new radiation. Old steam traps abound with nicely painted in silver. Not a scratch on the bolts. There also exists 2 zone actuators and a hot waterside arm heater for baseboard heat. Someone removed 1 section from the boiler. Yup, there was a hole in it. Much water hammer.
I presented my case and it was denied. Now there is a new boiler. More water hammer than before.
You get what you pay for.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
