Seeking DIY Help for Roof Leak Patching
So, I've been wrestling with a frustrating roof leak issue at my place for a while now. Turns out, it's not around the chimney like I thought, but at the peak of my roof. The previous owner went a bit wild with layers of roofing – it's like a shingle sandwich up there.
Here's the problem: Over time, some of the little fasteners have given up, and water sneaks through those gaps when it rains. It's a real pain to track down the source of the leak, especially with the layers of old roof involved. I've been doing the yearly grey tarp replacement routine, but it's not exactly a long-term fix.
So, I'm thinking of a DIY solution. Could I just grab some roof tar/goop and some mesh/fabric, and patch up the problematic area at the peak? It's not the prettiest fix, but I'm hoping it'll keep the leaks at bay until I can tackle a proper roof redo.
Any thoughts or other DIY suggestions for dealing with pesky roof leaks?
oliviajacko said:
Hey everyone,
Also i got information from Roof Replacement Sterling Va
any of your help is appreciated0 -
I have used a gallon of flex seal rolled onto roof at work. It stops leaks very well. Has good life span too. But this is on a flat TPE roof.0
It seems that once the nails get loose, even if you tar over them they will push the tar up when its dried. Pulling the nails in motion and filling those holes with tar, then placing new nails (and coating them with tar) might hold, but thats quite a bit of work.
I used rolled roofing once, on an old shack of a house. Didnt look too pretty but worked fine.
Currently in building maintenance.-1
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
