Thermostatic Radiator valves for one pipe system
davidp156
Member Posts: 1
Does anyone have any recommendations to install thermostatic radiator valves for a one pipe system?
- I like the Danfoss eco for its Bluetooth property but worry about replacement
- Or would a macron or honeywell be a better option
Inlet valves or air vents?0
Critical question. Since inlet VALVES won't work on one pipe. VENTS will, provided the boiler cycles often enough.JUGHNE said:Inlet valves or air vents?
It is my understanding that TRVs are used to prevent over heating. I have seen them in use. It is my advice that if you have a one pipe steam system in a building that has more than 12 units [Apartments] or more than 4 stories, that you avoid their use. There are other things that you could do centrally that are less costly and intrusive to reduce over heating1
- 116 Geothermal
- 15.8K Strictly Steam
