Thermostatic Radiator valves for one pipe system
davidp156
davidp156 Member Posts: 1
edited March 2024 in THE MAIN WALL
Does anyone have any recommendations to install thermostatic radiator valves for a one pipe system?
- I like the Danfoss eco for its Bluetooth property but worry about replacement
- Or would a macron or honeywell be a better option
  • JUGHNE
    JUGHNE Member Posts: 11,615
    Inlet valves or air vents?
    Jamie Hall Member Posts: 27,630
    Critical question. Since inlet VALVES won't work on one pipe. VENTS will, provided the boiler cycles often enough.
  • ARobertson13
    ARobertson13 Member Posts: 149
    It is my understanding that TRVs are used to prevent over heating. I have seen them in use. It is my advice that if you have a one pipe steam system in a building that has more than 12 units [Apartments] or more than 4 stories, that you avoid their use. There are other things that you could do centrally that are less costly and intrusive to reduce over heating
    Long Beach Ed
