What is this pipe spewing steam?
ariccio
Member Posts: 83
A family member is staying at HSS. I can't help but notice this pipe outside their window.
Seems to my gut like a bodge pipe installed to get rid of steam that's in a place it shouldn't be anyways... What could it be? It's blasting huge amounts of steam constantly.
Actually, its not steam, its vapor. Could be the air discharge from a vacuum pump.
The vacuum pump discharges saturated air. A typical discharge air temperature could be 150*F. When that hot saturated air comes in contact with the cold outside air, that moisture condenses out, and you see clouds of vapor like those in the picture.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
@ariccio might be English. Bodge = mistake8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Yes, common in electronics:
(Britain, Ireland) To do a clumsy or inelegant job, usually as a temporary repair;NJ Steam Homeowner.
In US technical English that would be "kludge".—
Bburd0 -
HSS is the Hospital for Special Surgery in New York City.0
Heh, sorry, I don't get notified by email when there are replies
HSS is a New York City hospital where a family member needed some suspension work done. (Do you know how much those mechanics charge to swap out an OEM hip joint for an aftermarket model?!)
I called it a bodge pipe because, well, it's a rusty pipe dumping steam into the cold outdoors. If there was that much steam left *on purpose* after it did it's work, and we're not talking an old timey steam engine train, I'd imagine someone would do something reasonable with it. It is winter after all, and hospitals need ridiculous amounts of makeup air and hot water, I'd imagine that anybody paying bills would hate to waste it intentionally.
The engineer and accidental institutional sociologist in me has a gut feeling someone got tired of working in a hot and steamy mechanical room, lacked the authority or motivation to fix some underlying problems (like steam traps leaking steam), said "**** it!", drilled a hole in the wall, and got to work with a box full of pipe fittings.
The fact that the pipe has like 5ft of riser on it also has me wondering if it was getting those heat pumps nice and soggy in the winter, which is just great for frost formation. My vivid imagination pictures someone else coming along, seeing an undocumented short pipe dumping steam, and deciding the best course of action was to make it about 5ft taller 🤣
Bodge is a word that EEs tend to use for itsy bitsy wires soldered onto PCBs when someone screws up and it's too late to change the layout in production. You'd be amazed how often EEVblog tears some actual on-the-market product down and sees wires awkwardly running around the board.0 -
Oh what the hell? I type out a long reply and it gets eaten?!0
Sorry @ariccio. Your post got held for moderation, but I've sent it through.ariccio said:Oh what the hell? I type out a long reply and it gets eaten?!
You can set up email notifications in your profile settings. Also be sure to check your email spam folder to make sure notifications aren't being sent there.President
HeatingHelp.com2 -
Steam is wasted constantly. District steam systems usually dump all the condensate. Steam systems with traps constantly blow steam out of boiler feed and condensate tank.
Huge number of BTUs lost and it goes on everywhere.
Sometimes due to lack of maintenance.
Sometimes that's the way it is.0 -
Hmm, y'know, I think I've read of this when I've read of the devices that cool condensate below some legal limit before allowing it into the sewers.EBEBRATT-Ed said:Steam is wasted constantly. District steam systems usually dump all the condensate.
I can imagine this is some comical amount of wasted energy worldwide. I wonder if anybody's ever estimated exactly how much waste this amounts to. The Japanese Gaia seasonal geothermal heat pump snowmelt system gives me inspiration thinking how we might use all this wasted energy to clear snow off the city streets instead of spreading enough salt to turn our cars back to iron ore... The gears in my head are turning now, but I have actual work to do.
I finally noticed the setting for email notifications. 🤦♂️2 -
- 117 Geothermal
