A baby 👶 weatherhead....neato
  • Intplm.
    Intplm. Member Posts: 2,835
    A infant weather head with only two wires. Never noticed one of these before.
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,414
    Me neither...cute!  Mad Dog 🐕
    Intplm.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    What does this feed/run?
    Doesn't look to any code unless low voltage.
  • delcrossv
    delcrossv Member Posts: 2,189
    edited March 2024
    There's teeny weatherheads feeding detached garages all over the city here. No bushing on the down conduit is a no-no, however.
    Reminds me to replace the cable at my MIL's garage with an overhead set-up.
    ethicalpaul Member Posts: 8,177
    Looks like just a switch maybe?
  • JUGHNE
    If a line voltage switch, then there seems to be no grounding for the metal enclosure.
    And the wire loop is not protected from physical damage.....looks to be possibly less than required height above grade.
    delcrossv
  • delcrossv
    ...and excitement could ensue. :o
    mattmia2 Member Posts: 15,651
    Probably a disconnect for an air raid siren or cable tv power supply or something pole mounted and metered at a fixed rate like that. The ground would come up from the ground.
  • Mad Dog_2
    NYC suburb...Cut it sit and wait in a car and see who shows up...ha ha 😉 😎 mad Dog
    PC7060
  • Mad Dog_2
    Ill.bet it's low voltage...too low to the ground for line voltage, if tampered with. Mad Dog 🐕
    rules don't apply to utilities and cities like they do to you or me.
    PC7060ratio
    EBEBRATT-Ed Member Posts: 19,642
    edited March 2024
    No bushing needed on the down pipe if it is a sleeve.
    The only way that's legal if its line voltage is if it's 120 volt
    And the weather head is too low probably utility work.
